MikeSalt
Been playing with it for a little while now, and I've got the mode-switching knack. I quite like how that works because you have to be very deliberate about it. If you were using it for signalling, it won't mode-shift by accident.
To me, it is an LED Surefire E1e replacement, without the hassle of swapping between low-output and high-output bulbs. I've compared the tints of the Lumens Factory HO-9 equipped E1e this Haiku and a bunch of other LED lights and this makes the E1e look a bit yellowish. Shining against photos with flesh-tones in, the Hi CRI Haiku rules them all.
The tension of the clip is spot-on, the only issue I could see is if I were to try to clip it over a belt, which is thicker than my pocket of course. However, I put security above all else when it comes to a clip, so this is just so right.
