Will now that you did the new motor n stuff how fast is your saw ?
Since I know the coolant lubricates and cools, I do run faster speeds and higher pressure than before, but "how much faster?", I don't know, since I am not trying to push it too hard to find out. If/when I do push it really hard (too much down pressure on the cut) the blade will pop out, so there is a sort of "built-in" protection.
A big benefit of the conversion is how much cooler the "true" 3/4 HP motor runs - I mean dramatically cooler. After cutting all of that angle iron it was just warm, while even lighter cuts would cause the "Chinese 1/3 HP" motor to get so hot after 1/2 hour that it got hot enough to burn your hand (can't keep it in contact with motor). Now I can cut continuously for hours without worry. I am sure I will wear out the bearings in a few places before the motor ever wears out. The blade also stays relatively cool, which of course increases longevity of the cutting edge.
One thing I noted, in regards to the blade: for cutting that "relatively" thin wall tank, that blade of 6-10 TPI is the WRONG one to use. BUT, because of the piston and variable speed, I increased the speed AND lower the pressure on the cut surface, which allowed me to cut the thin wall stuff with no problems - yes, it takes a little longer to cut this way, but nothing over-heats. It was awesome
Here is a short video. Not cutting at max speed, but not going super slow either. Since I was going to weld the pieces, I set one up to be cut in the bandsaw while I go and clean/grind/bevel - this setup allows me to work in parallel without having to babysit the bandsaw:
