Krazymonkeys
- Joined
- Jun 16, 2019
- Messages
- 3
I have a big plate, maybe 6 or 7 inches square. It has 70 LEDs with room for about double that. It came from a street lamp which was rated 13000 lumens at 96 watts. No idea if it actually reaches that at that wattage but I do know the driver is rated for a little over .5 amps and 375 VDC max. I also know that it is BRIGHT. The driver works on 120VAC and it would be ok for a plug in lamp once a reflector, housing, etc is fabricated for it, but I'm curious if it can be made into something battery powered for portability. Obviously, nobody really needs 13k lumens in a flashlight, but I also can't see much meed for a work light that bright. One wrong turn of the head and you're not going to see much for a while. Anyone have any ideas on what could drive this thing using batteries? I'm hoping to use 18650s but I'm open to suggestions.
