Assume in this discussion the two LEDs being compared have adequate heat sinks.
I believe it is well known around here that the XM-L2 reaches the highest phosphor surface candela (lm/mm²) over XP-G2/XP-E2 when speaking of a chip being fully driven at maximum spec or above spec amperage levels.
This generally defaults in an XM-L2 choice for high Kcd large throwers (aspheric for example) as it will cover a square of more area, but at higher lumen per area. I believe this is why the German-built light that reached somewhere around 2.2 million Kcd (200mm lens) at a competition they have, used an XM-L2 in his light.
So in your opinions, is there any other LED out there that theoretically could reach higher light density at the die level, over the Cree XM-L2?
I noticed that Luminus LEDs of course are more wattage hungry, but they have much lower die-to-solder point C/W thermal resistance. I wonder if they could be pushed harder for that reason if the amperage/heatsink was there to do it.
Comments?
Comments?
