The emitter is direct mounted, no star. After being on high @ around 3A I get some smoke but very little heat. I used to have it flowed on a star and then AS'd to the copper but it was producing a lot of heat but no smoke.
If your copper mount is not hot after running it at 3A, then I believe that your thermal contact is very poor & the heat might be trapped in the emitter, which will eventually kill it.
I recently tested a XM-L2 on a copper star direct from a DC power supply at 4A.
After 10 secs, the whole copper star because too hot to touch.
You might wanna check the contact surface between your emitter & copper mount.
Like Epsilon said, the 2 surfaces gotta be very flat in order for them to have good contact.
