So I was cutting some 1" 6061 square bar to 1.375" chunks and had a part jam up the works. Didn't notice it as I had stepped away and the compressor had just kicked on. By the time I got back, the motor was stupid hot (too several hours to get back to a normal temp thanks to the thick cast iron shell) and it wouldn't turn on. Tried to fire it up the next day and nothing. So I start looking at motors and how much work I would have to do to put one in and it put me to the point of just selling the dang thing and buying a bigger one or a used cold saw. So today I pulled the motor to see what the issue was and if it was just a cap or something. Cap was fine, but I found that there is a Thermal cut-off fuse that no longer had continuity. So I did some searching via the web and found that the Fry's thats 45 min away had one on the shelf. The old part was an SWC SW129T (250v 15A 128°C). The equivalent they had was an NTW 8125. Did the driving, came home, installed it and the motor fired right back up. Apparently there was no damage done other than a couple ties were melted. So, long story short, if you have on of the small HF horizontal bandsaws and the motor dies, check the Thermal Cut-off fuse. Could be the best, cheapest fix.
The part is the shiny little metal bit at the top of the pic
