Yes, in my hot sweaty hands is the brand new 4 Sevens Mini Mk II with 1020 lumens from a single 4Sevens custom high-discharge rate RCR123A.
Review sample courtesy of 4Sevens.com.
1020 lumens from a tiny single CR123 light of about 2.17 in long -
that's roughly the equivalent of a 75 watt incandescent household light bulb -
but with the light concentrated in a flashlight beam....
(just for comparison a typical US halogen car headlight on high beam is about 1200 lumens)
Packaging -
Back -
Size -
left to right - AA battery, original 4Sevens Mini (in titanium), Mini Mk II, 4Sevens Quark Pro QP2L-X
left to right - IMR16340, CR123A, Mini Mk II, Quark QP2L-X head on Quark 123 body, AA battery
Heads -
left to right - Mini Mk II, QP2L-X
The lens of the Mini Mk II is not plain/flat as in most other flashlights -
but it is dished with a frosted center dome -
According to 4Sevens Specs on the Mini Mk II -
this is a TIR Optic lens
(see Wikipedia explanation of Total Internal Reflection,
and this pdf of types of TIR lenses suitable for LEDs)
Flex Charger in kit, and the 4Sevens custom high-discharge rate RCR123A -
The Flex Charger's contacts have very strong magnets to hold on to the battery terminals.
At first I was very concerned as those contacts are not marked in any way as to which was positive or negative,
and high discharge RCR123 are not to be taken lightly...
I immediately read the manual -
I would also caution since it is so easy to have the charger contacts stuck to each other -
always make sure they are attached correctly to the battery terminals before inserting the USB connector to a charger/supply
Manual -
$64K question - how bright?
I only have one flashlight that's even in this league - the 4Sevens Quark Pro QP2L-X with burst mode of 780 lumens
despite that, hopefully I can still do some interesting comparisons -
The closest apples-to apples using the QP2L-X head on a Quark 123 body and IMR 16340
vs. QP2L-X using 2x CR123A (standard configuration)
I wondered if the Mini Mk II would be as bright using an IMR 16340 reputed to be capable of high discharge -
since I don't have two Mini Mk IIs to compare, I compared it with QP2L-X in standard configuration with 2x CR123A
interesting huh?
May be pocket rocket is finally appropriate?
EDIT to ADD -
Measurements by reppans
EDIT to ADD 2 -
reppans made some measurements of the supplied 4Sevens RCR123A battery (link to his post)
Packaging -
Back -
Size -
Heads -
The contacts are not specific to either the positive or negative terminals; just make sure that one contact is attached to each of the two battery terminals.
Manual -
interesting huh?
EDIT to ADD -
For the record, my lightbox is calibrated to what I believe to be US ANSI and ties up closely with my HDS 325 (@0.02 and 325) and ti-force's review of a couple Quarks (btw, ti-force is the only CPF reviewer that claims very accurate lumens using laboratory tested calibration lights). This scale is lower than that used by Selfbuilt, and most Chinese domicile companies - for example, the best I can get off my 1st gen ZL SC52 is ~230/440 lms from an Eneloop/14500 (all the other modes are similarly off as well).
My measurements on a fully charged OEM cell are as follows, runtime calculated assuming 550mah batt spec is correct:
- Max 1000-1050 lms, 3A current draw, 11 mins calc assuming continuous
- Medium 280 lms, 0.514A, 66 mins
- Low 17 lms, 35ma, 16 hours
- Moonlight 0.25 lms, 4ma, 138 hours
My sample holds max (very flat) for 30 seconds, and then ramps down over the next 10 sec. to ~325 lms and then regulates flat again - I don't know where the 15sec comes in, except to say it could be 47s "under promise/over deliver" thing, and also perhaps to technically qualify for the 30sec ANSI FL1 rule. The light seems to hold a flat 1k+ over 4V, and I'm even getting a flat 800+ at 3.6something V. The head gets warm, but nothing uncomfortable against your upper lip.
EDIT to ADD 2 -
