U
user1016
Guest
Tonight, I switched on my Maglite 3D with Seoul P7 Mod.
This mod has been faithful to me since 2009 with no major issues, although prior to this one, I had a P7 failure because I was very new to lights then and placed my batteries directly in the maglite fresh from the charger for immediate use, leaving no time for the voltage to stabilize. I remember that when it eventually blew the LED, the LED turned a bluish hue and the maglite switch area grew very very hot, literally too hot to hold.
So tonight, I was laying in bed relaxing for a bit, I put a blue filter over the maglite 3d to provide some cheap blue ambient lighting for the room. About 2 hours later, I reached over to switch it off and noticed that the entire maglite was red hot. I immediately whipped the batteries out, and the maglite was put off to the side to cool off. It wasn't producing the same blue hue as my last failed LED mod, and I always let my nimh rechargables stabilize for about 30 mins to 2 hours after coming out of the charger. This one had been sitting all day before it was used so the voltage should've dropped.
[EDIT Just checked voltage of the batteries, they're scoring 1.27v each, if I'm not mistaken, they should be around 1.2 or lower, strange. They're Jaycar nimH 9000mah rechargable D cells if that is of any use to anyone who can help me figure out what's going on)
My question is, what's the next step? I don't want to put them back in and have it blow up, what should I do to test whether or not the mod is faulty (or perhaps the batteries?).
Also, while I'm at it, what's the best plan to have for a battery explosion? I keep an Australian standard B:E Powder based fire extinguisher (Flammable, combustible and Electric fire) handy at all times in case of fire.
