HgRyu
This thread is closed.
Dealer lighthound and BugoutGearUSA.com have some stocks.
Please order BitZ from one of them if your location is North America.
BitZ Pocket flashlight..
Specification
Driver and Brightness levels, Hidden Signals
Caution
Price and terms,
Specification
- Material : 6061 Aluminum Alloy (Head, Body), Titanium (Bezel, Clip),
- Finish : Type III Hardcoat Anodized Natural Finish
- Lens : Sapphire Crystal Glass, optical grade (Anti-Reflective coating for one side)
- LED : SSC P4 bin - USXOH
- Driver : Buck-Boost converter with 3 regular brightness levels and 4 hidden signals.
- Reflector : High quality Orange Peel aluminium reflector
- O-ring sealed Twist On-Off (no battery rattle)
- Battery : One 3V CR123A or one 3.6V RCR123A (recommend AW's protected Li-Ion cell)
- Dimension: Diameter 20.3mm, Overall Length 72mm
- Hole for DIY Tritium vial or Glow-Powder on tail (hole size for 1.5mm X 6.5mm). Sorry, No Tritium for international shipment.
- Accessories : Titanium Pocket Clip, 2 Split Rings (one stainless steel, one brass)
- No commercial packing
- BitZ Pocket use Buck-Boost converter and it will control power to the LED even though you use 3.6V rechargeable Li-Ion battery. So, LED will not be damaged by unregulated high current from Li-Ion battery. Off course, birightness by regular 3V CR123A and 3.6V rechargeable Li-Ion battery will be same.
- Input voltage range : 1.8V ~ 5.5V
- There are basic 3 Brightness levels (Medium-Low-High) and hidden 4 Signals (Strobe-Locater-Extreme Low-S.O.S.)
- Brightness (estimated) : High (120~130lumen), Medium (30~40lumen), low (10lumen)
- Current to LED (tested) : High (500mA), Medium (150mA), Low (30mA)
- Rumtime (tested) : High (1~2 hours), Medium (3~6 hours), low (12~24 hours) depending on 3V or 3.6V.
- Runtime for Signal mode (RCR123A, CR123A) : Strobe (8, 12 hours), Locater (24, 36 hours), Ext.Low (45, 70 hours), S.O.S. (8, 12 hours)
- Basic 3 brightness levels has Memory Function. You will get next level by Off and On within two seconds.
- You will get into Signals by consecutive 8 On and Off. No memory function for Signal.
- Locater signal : useful mode for tracking and camping as "follow me" signal or location signal.
- Extreme Low : This mode is useful as a overnight candle at tent. Current to LED is 10mA.
Caution
- We recommend you to use AW's protected Li-Ion battery (R123A) if you want to use rechargeable battery. We don't recommend other Li-Ion battery.
- Do not open bezel, otherwise you will lose guarantee. You will also lose sealing and can't find anti-reflective coated side of lens if you open bezel.
- Do not use pocket clip for belt. Pocket clip don't have enough strength(tention) and room for thick leather belt, use clip just for thin fabric pocket. Use T6 Torx wrench to remove clip from body.
Price and terms,
- Price is U$135/pc
- Shipping via airmail to everywhere at U$5.
I'll ship via registered airmail if your post office have tracking service. (not available to USA, USPS don't have airmail tracking)
If you want shipment via EMS(tracking), actual shipping will be applied (FYR, cost will be U$22 to US, U$20 to Europe, U$15 to Japan and China) - Payment to [email protected] via Paypal only.
- Please add your "CPF ID" on your Paypal details.
Please mark "registered airmail" if your post office have tracking service.
Some pictures and details,
Runtime Graph,
Color reference,
Here are more photos...
Thanks.
