SureFire P1R Peacekeeper rechargeable flashlight
Kif
Mississippi
I collect Surefire flashlights for years and this is my first time pre-order New Surefire flashlight. This is the first Surefire official made flashlight using 18650 rechargeable battery and I want to be the part of this history.
I ordered the B version which has dual LED output. 600 Lumens on high and 15 Lumens on low, and with clicky type tail cap.
The following are the photos
front side of box
back side of box
600 lumens with 1.75 hrs run time and 15 lumens with 46 hrs run time
box open view
P1R flashlight
18650 battery charger
using with indoor power cord
using with car 12V adapter
back side of the 18650 battery charger
the included 18650 is 2600 mAh
the battery was made in June 2014 (?)
It finally has newer CREE XML2 LED
Size comparison with Fury P2X and P3X
The lumens of the P1X is between P2X & P3X and the hot spots are all very similar. The P1R will be very handy in actual use even with a little bit expensive than Fury P2X
Update:
Post a photo with head battery contact side
There is a small spring like other newer Fury/6PX/G2X
It can use flat head 18650 without any problem
I only have AW protected 2600 mAh 18650 so I am not sure if the P1R can take bigger 18650
Top to bottom:
AW protected 18650 2600 mAh
Surefire 18650 2600 mAh
AW protected 18650 2200 mAh
skyfire
Los Angeles
just what i need. another surefire to add to my "to buy list". ha!
the P1R looks great. i like its styling more than the fury. pleasantly surprised it came with a XM-L2. :thumbsup:
any ideal where the charger was made? that charger is interesting. "employs CC/CV charging". lifetime warranty should apply to the charger as well?
thanks for sharing!
StandardBattery
MA
Nice photos. The battery looks like it might be unprotected, is that true? Did you see if any common 3400mAh cell would fit?
RobertMM
Las Piñas, Philippines
P1R is rated 1.7 and 46 hrs with the included battery, so if 3400 mAh cells fit, a bit of math tells us we'll get 2.2 hours on high and 60 hours in low? Awesome. :-D
Up All Night
Nice stuff!! Thanks for posting Kif!
Perhaps the first CPFer with SureFire's first factory 18650 torch? First poster for sure! Congrats!:thumbsup:
newbie66
Malaysia
Nice! If the battery here is unprotected then hopefully someone can test if it fits protected batteries.
pjandyho
Singapore
How do you tell if a battery is protected or not? Is there something I should look for when ordering battery? Dealers like Fasttech in Hong Kong don't even know what a protected battery is when I emailed them to enquire. Considering the safety standards set by SF, I don't really think they would risk their reputation by providing an unprotected battery, but I am just making an assumption here.
RI Chevy
Ocean State
You should be able to tell by looking at the wrapper on the battery. Also the size specs of the battery. Longer sized, ie. 68mm or more are usually protected, 65mm are usually unprotected.
http://www.lygte-info.dk/info/battery protection UK.html
pjandyho
Singapore
Thanks. I was just curious how StandardBattery could tell that it is an unprotected battery just by visual acquisition alone. Doesn't seem to indicate on the wrapper.
Kif
Mississippi
I don't have bigger 18650 so I am not sure if P1R can fit bigger battery
There are still some room when putting in 2600 mAh 18650 though
I guess this Surefire 18650 is protected since there is a small diameter change in the tail side of the battery
I also update a photo compared with other AW batteries
Up All Night
The battery photos would seem to show they are protected. The head-on shot looks like a circuit running the length of the battery under the wrapper and the other shots appear to show a board added on the negative end. The boards are typically slightly smaller and are not always centred.
My only experience with unprotected 18650s are from drill packs and they are the same diameter right down to the negative plate, no taper under the wrapper.
I would agree with pj, I can`t see SureFire putting out a rechargeable LiCo battery without a pcb. But hey, I`ve been wrong before!
RI Chevy
Ocean State
The Surefire battery does look like it is protected to me as well, based on the photo provided. I also seriously doubt that Surefire would sell or include an unprotected cell with this new light.
pjandyho
Singapore
That was what I noticed too when looking at the head-on photo of the battery.
