TM06vn - True Tiny Monster MUST HAVE!
Skylumen
Must Read & Agree Before Purchase
Factory Link Click Here
TM06vn XML2 PDTn Video Click Here
See post 2 for photos & videos
A. $200 Current Boost only from 2.2A to 2.8A
B. $225 Dedome Factory XML2 LEDs - Might have more than 1 green LEDs but the blend is usually not bad
C. $250 XML2 PDTn or XML2 U3 Dome On (XML2 U3 dedome has a hint of green so not recommended)
+ $5 for "V54" hand engraved on the bottom of the tail cap.
+ $18 if you are outside of USA
+ $7 Dark Heated Bezel
If you want shipping insurance please ask
Email/paypal: [email protected]
Skylumen
Nice beam dedomed. I like the huge spill. Does not look much brighter then stock to me.
Only .6A increased per LED so it's not much. I want to keep the UI well spaced and useful.
However if you want a larger noticeable gain in lumen then put in new XML2 U3 as outlined below
Estimate Factory 3200 LED Lumen at 2.2A per LED
TM06vn with XML2 U3 Dome on ~ 4850 LED Lumen at 2.8A per LED
tyxxvxl
S.L.C. UT.
Very cool Vinh!
So many awesome new lights.
Maybe after christmas I'll actually have money again :)
Ty
Skylumen
Very cool Vinh!
Ty
I don't have a sample here to compare but its noticeably shorter from my memory and it's extremely slender for a 4*18650. Look at the head size vs the S6330vn
Skylumen
I have tiny hands and look how small it is! The size surprised me for a 4*18650!
Skylumen
Light built quality and design is exceptional!
Large thick heat resistance wires
Thick LED copper base with direct thermal path
Each LED heat sink directly down to body
All springs has a flat file top for great current transfer
Threads are large and strong
Stainless strike bezel is thick but rounded so there are no sharp corners
Glass is ultra clear
reflector is smooth with no manufacturing imperfection
All LEDs are 100% centered by smart design
Tail stand firmly with large lanyard hole but forward switch is still easily accessed
The nylon thing I don't like is the excessive body printing
Look at how thin the reflector depth is. How much this light throw with this reflector really beats me.
Skylumen
Are you sure it's per LED?
Would the 'XML2 U3 Dome on' require high discharge cells?
If so and if you can ship the light with the cells inside then I'll probably take one. Shipped locally though.
Would this complement my stock TK75?
Ta.
it can't be 2.8A total so yes it's 2.8A per LED.
All options require high drian for max performance although any cells would work fine. This light is much smaller than your stock Tk75 with performance that i would say almost identical.
