Replacing an mr11 HID
Fibre
Ive got a diverite mr11 canister light that i want to covert to led.
i originally planned to use a sumpdonkey dropin but they are now discontinued.
I looked at the design and can replicate most of what they did, but am not certain about the best way of getting three leds in the correct layout to use a ledil cute ss lens.
Should i buy three seperate cree leds on stars and try and hack the stars so that they fit together or try and find a three led star. If the later, can someone suggest a source in europe?
Thanks
Deeperdiverdude
Hi,
I have done a similar job on a custom diver light, hope this picture helps:
I used three individual cree xmls and they were held in place with thermal adhesive and the the lens unit.
T
Fibre
That's basically what I am trying to achieve. I finally found a three xml board in Germany and connected it all together with a do driver and my original 12v sla. It produces a bucket load of list but the led pub also gets red hot as well.
Its very floody oozy as well so I'm currently looking for a single Cree and aspheric solution too.
Fibre
Well I finally got a couple of heat sinks made and assembled my test rig. I had the Lexie lens, a three xml board from a place in Germany and a cheap 3a driver from China.
on day one I ran it in low power and up against a halcyon head it held its own.
day two I tried it in full power mode and it blew the halcyon away - for what I wanted anyway. However I soon discovered that the driver needed more heat sinking than I thought - the burn hole in the chip sort of gave me a clue.
so I'm now at the stage of looking for a more sensible driver solution. Dx seem to be light of 3a Buck drivers so what is the solution? Do I fork out for a more costly setup like the taskled or black power drivers or wait for dx to get some new 3a boards.
If if I go for cheap boards, what's the best solution for heatsinking. The ones I have have a coil directly above the voltage chip so I can't fix directly to a heatsink.
