The Lumapower Avenger RX, the smallest tactical flashlight
lumapower
Hong Kong
The all new Avenger RX is now ready to ship.
Original info. at CPFMP for your reference : [CLICK HERE]
Basic Specification. :
User Interface : SMART UI 2.0, 2 way memory lock
Brightness level : 100%, 40%, 15%, 3%
LED : XP-E2 cool white (optional neutral white, warm white)
LED output (Lumens) : 85 (Alkaline, NiMH), 235 (4.2V Li-ion)
Reflector : SMO aluminum
Coating : Type III HA Black
Battery source : Alkaline, NiMH, Li-ion (Standard style), 2xAAA Alkaline, NiMH (Pen style)
Water resistance : 2M 30 minutes (IPX-8)
Power switch : Twisty, Clicky (both included in standard style)
Thread lock design : Yes
GITD : front o-ring and clicky switch cap.
Removable pocket clip : Yes
Length :
Standard Twisty : 71mm
Standard Clicky : 87mm
Pen Style : 131.5mm
Head diameter : 14mm
AS a reply to MojaveMoon07 about the cd values :
The max. cd value with 10440 is : 1800
So, the calculated THROW distance is : 85 meter.
the reference retail price here :
The Avenger RX with more options for your choice now :
Stock LED : XP-E2 CW
1. Avenger RX Twisty : USD37.
2. Avenger RX Clicky : USD39.
3. Avenger RX Twisty + Clicky : USD41.
4. Avenger RX Pen (Clicky+Large pocket clip) : USD45.
5. Avenger RX All-in-1 : USD55 (including both switch, both battery tube, both pocket clip and diffuser tip)
A. Small pocket clip (for 1xAAA) : USD1.5
B. Diffuser tip : USD2.5
C. Change to XP-E2 NW : USD1.
CPFer can now order the ALL-in-1 package at discount price of USD43.
And you can specify your LED at the same cost.
Other package besides All-in-1 offer will get a USD5 discount and a FREE gift together with your order.
You can send PayPal to [email protected] to place your order now.
I will update this threads very soon.
Thanks and best regards,
Ricky - Lumapower CS
lumapower
Hong Kong
I like the specs for sure. However, that clip looks a little suspect.
Hi Str8stroke,
The All-in-! package with 2 clips for both 1xAAA and 2xAAA style.
The small clip for 1xAAA should be solid enough as I have use it personally for more than 4 months without any problem.
And the larger clip for 2xAAA being more solid to hold the weight.
Best regards,
daflip702
City for losing your mind/wallet AKA Las Vegas
Is there a keychain attachment point/hole on the clicky tail? I need a new capable keychain light to replace my old one. I can't use twistys because they have been unintentionally turning ON in my pocket (My job requires a lot of ground work and the keychain rubs inside therefore accidentally turning on). Thanks
Fnx45
I just sent Paypal for the all in 1 package in Neutral White. Can't wait to try it out, now I just have to find a good source for 10440 batteries.
lumapower
Hong Kong
Hi awiseguyay,
Yes, the clicky module with a forward clicky switch installed and the switch is replaceable and you can change the switch cap too.
Best regards,
awiseguyay
Hi awiseguyay,
Best regards,
thanks! one more thing if you please... what are the lumen levels with a single 1.5V AAA?
lichan
I just ordered the All-in-1 CW via PayPay. What types of 10440 batteries work in this? Flat-top, button-top?
Kilovolt
Lake Como, Italy
The positive contact in the head of the Avenger is surrounded by a plastic ring that prevents a wrong insertion of the battery. Consequently only button top cells can be used.
Personally I have a number of old AW 10440 cells and rotate them.
Mountainman38
Why is there no more info available about this light?
It seems like a great AAA light -- clicky switch, accepts 10440's, has multiple settings -- but I can't seem to find anything except the one german review.
I would like to see some outdoor beam shots, run time graphs, comparisons with the much cheaper but similar Lumapower LM21, the Fenix LD-02, the Lumintop Tool AAA, and other similar lights.
Where's the love?!
