- Joined
- May 4, 2014
- Messages
- 648
I received a brand new Peak Eiger directly from Peak last week, and while I do love the little powerhouse and appreciate it as an amazing piece of kit I'm having some problems with the QTC not giving full effect depending on where on the pill you press (push down on one side of the plunger and it seems "normal", push the other side of it and it only gives you 40%). I've contacted Peak regarding this and if this problem persists I can send it back to have it adjusted, but living in Sweden that would mean a long and expensive trip for the light for a problem that someone else might have already solved in an easy manner. I've tried finding a solution but none that works for the 2.1 pill.
Any help is welcome and I hope this is in the right subforum for it, otherwise I leave it to the mods to correct my mistake.
