ReyLight: 18350/18650 Titanium Flashlight Host, with 10 trits slots.
hbk_rey
A few Hosts available.
Sorry for the earlier improper post. And I hope this new one will not mislead any member. Thanks.
I made several custom lights for the other forum, now introducing the Ti Host.
Host Only. You Must have:
Lens,emitter,driver, reflector, battery and Ability of assembling. (2 kind of copper pills,O-rings and switch included.)
Here is what I did with the host. You can also try triple xp-g2 or others.
#1: Triple nichia 219B in parallel + Carclo 10507 optic + 4.5A driver.
#2: XM-L2 or XPL + aluminium reflector +20mm glass lens + 8*7135 driver.
#3: 3535 UV LED + aluminium reflector +20mm glass lens + 3*7135 driver.
etc.
Battery:18350/18650 (with extension) (16340/CR123)
Tritium:9 slots in head, 1 in button. (6*1.5mm)
Ti Clip (In processing): 46 mm length. M2.5 Screw, 7mm holes distance from center to center. Fits for Nitecore D10/D11 and more.
DIY NOTE:
1. 20mm lens.
2. 17mm driver.
3. Reflector less than 11.5mm height.
ChibiM
Holland
Re: 18350/18650 Titanium Flashlight Host, with 10 trits slots.
Definitely!
Looking forward to the actual light!!!!
Thanks for posting.
jonwkng
Singapore
Thanks for making this happen! :)
Chicken Drumstick
UK
Another thumbs up from me! :D
Ladd
US
Beautiful light. Should be a fun build.
hbk_rey
Still trying. We shrimp the inner size a little, the drilling will be done today, we'll see. if it doesn't work, we then go to 25.4 or 26mm.
ChibiM
Holland
I got Rey`s proto type in hand, and here are a few pictures:
next to a Convoy S2+ which inherits the same threading inside the head, so the pills are interchangeable.
Next to a Sinner`s 18350
Some things will be different on the actual production type.
Ladd
US
When are these going to be ready to buy?
Rey has been taking orders for over a month now. PP is in seventh paragraph of OP.
Given that they are in production as we speak, delivery should/could be imminent. As of a week ago Rey mentioned shipping by the end-of-month. To be realistic, a project like this could probably experience glitches at any moment.....
Edit: They are now shipping
cubebike
HK
Received it yesterday. Anodized and stone washed. TIR with Xpg2. 10 trits installed. The body was too tight to take protected Panasonic 18650. The tail switch was a bit tricky to use and still figuring how to avoid jamming to the housing. The Triple Nichia 219 from Rey was not working, hopefully will receive another one from Rey next week.
It was fun to DIY. The quality was quite good. Suggestion to Rey are improvement to tail switch design (compatibility with Mcclicky) and the body to take larger( fat) protected 18650 cell.
gunga
Vancouver, BC, Canada
Also tailcap bolts need to be drilled properly (ie, around the light, not straight into it). I have one built, overall, pretty happy, great price and awesome with 10 trits.
Not perfect but very good value.
BTW, great job on the finishing! Care to share any details on how you did it?
