Features
● CREE XM-L2 U2 LED, with a lifetime of up to 50,000 hours;
● Tail cap dual-push-button switches, one to control on/off, the other for selecting desired output mode, three types mode-switching;
Output & Runtime
High (1000 lumens, 1 hr. ); Mid (150 lumens, 6 hrs ); Low (16 lumens, 80 hrs ); Strobe
● Constant current circuit, constant output
● Effective range of 208 meters
● Uses one single 18650 or two CR123A batteries
● Working voltage: 2.8~6V
● High quality metal smooth reflector maintains great throw distance and spread with an ideal beam pattern
● Dimensions: 141mm (length) x 34mm (head diameter) x 25mm (tail diameter)
● Weight: 117g(battery excluded)
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Accessories: Clip, Lanyard ,O-rings
