SUNWAYMAN P02A- EDC Penlight, Angel in your pocket
sunwayman
Features
● CREE XQ-E R2 LED, with a lifetime of up to 50,000 hours;
● Two levels of constant outpu:168 Lumens (2hrs)- 12 Lumens (80 hrs)
● Reverse Tail Cap Switch, fully depress the switch to turn on the light, and depress it halfway for different outputs
● Constant current circuit, constant output
● Memory Function, automatically memorize the most recent used mode before turning off the light
● Uses two 1.5V AAA (Alkaline, Ni-MH) batteries
● High quality reflector maintains great throw distance and spread with an ideal beam pattern
● Dimension: 130mm (length) x 14mm (head diameter)
● Weight: 24.5g(battery excluded)
● Aerospace-grade aluminum alloy
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Included Accessories: O-ring
Mr Floppy
I like the use of the xq-e but high CRI options?
Question on why there is memory for two modes?
Also what batteries were used for the run times?
WarRaven
Edmonton, Alberta
The memory idea is neat, so you could either have it start on high all the time or low then click for other level.
I'm liking it.
Mr Floppy
I'm liking it.
Not if you're a doctor and you forget what mode you had it on last and doing a pupil test give your patient a blast of light because the last mode was high.
WarRaven
Edmonton, Alberta
If he uses it or any instrument without at least first doing a quick rudimentary check then I ask, is it the equipments fault or end user?
Mr Floppy
Thus the inconvenience...
Discussion in the main led flash light thread. Wider things discussed if you would like to join?
naked2
Upland, CA
The ideal two-mode pen light for me, would be first click low, every time. I would buy that one (v2?); for now, I'll just have to win this one!
