XTAR H3 WARBOY headlamp 1000 Lm/400 Lm /200 Lm/70 Lm/1 Lm modes – Make your own rules
XTAR Light
Vendor
China
Life is a battle, so does your outdoor activities.
You never know what will happen in the dark.
With XTAR H3 WARBOY headlamp, you can get 1000lm light to kick off danger.
XTAR H3 War Boy is the best companion of your adventure.
XTAR H3 WARBOY Headlamp Features:
1. The latest premium CREE XM-L2 U3 LED
2. Five modes selectable: 1000LM/400LM/200LM/70LM/1LM
3. Wight only 50g (battery & head strap excluded)
4. Max beam throw 157m
For more information: please visit
http://xtarlight.com/05-chanpin/p-001-1.asp?styleid=369
Feel free to make comments
NorthernStar
Sweden
I´d like to see a review before i decide to buy it or not, but this Warboy light looks good.:) I have a question about it. From off if one double-click, will the light then start at 1LM (moonlight mode) regardless of which mode it had before it was turned off?
markr6
Nice mode spacing. Nice sleek design. It will all come down to exactly how the UI works; great question above ^
XTAR Light
Vendor
China
Yes.
markr6
That's good to hear!
Five modes – Press button for 1.2s to choose 1000/400/200/70LM modes - does that mean you hold it down for 1.2s+ and it starts cycling through modes from HIGH to LOW? If you are in 400lm mode and hold down, does it go back into 1000lm then start cycling down, or does it continue from 400 to 200, and so on?
XTAR Light
Vendor
China
No, it cycles through modes from LOW to HIGH, in order of 70→200→400→1000LM. Like if you are in 200LM mode and hold down, it'll go into 400LM. If you are in 1000LM and hold down, it'll go back into 70LM. I hope I made myself clear. :)
markr6
Perfectly clear, thanks! And I like the low to high sequence.
saypat
at 400 lumens it says it will run for 4.5 hours? That can't be right, can it? Or 200 lumens for over 10 hours? That would surely build up a lot o' heat, as it's a small light. Looks like a fantastic offering.
XTAR Light
Vendor
China
You don't have to worry about the heat since this H3 WARBOY has an intelligent temperature control system and over-temperature protection.
