BGroars
- Joined
- Jul 13, 2015
- Messages
- 946
Today, I' d like to show you a multifunctional tactical LED flashlight, called IMALENT DM21 CREE XM-L2 LED flashlight. This flashlight features latest touch control technology, tail rotary switch light control system, USB charging and tactical uses, extremely advanced and practical to use.
To know more details about this flashlight, you can read the following.
This flashlight has a compact size, one hand-controllable. It is 138mm in length, 25.4mm in body diameter and 27.5mm in head diameter, only weighing 89g without battery. It is considered to be palm diamond for night lighting and low enforcement officer on duty.
Applying CREE XM-L2 U4 LED, this flashlight can deliver up to 930 lumens maximum output,and it has a super long life span up to 50,000 hours.
Multifunctional tactical IMALENT DM21 CREE XM-L2 LED flashlight, with the application of the new touch-conduction technology, can be instantly switched on and off, man-machine combined.
This flashlight supports infinite accessible brightness control from the tail. Clockwise rotation can increase brightness. Anticlockwise rotation can decrease brightness. Through simple steps, you can fully control brightness as you wish at all time.
What' s worth to say is that this flashlight has a self-test feature. Every time when inserting the battery, the circuit will automatically run the polarity test. If the battery is in wrong direction or detected to be defective or faulty, the indicator on tail cap will not turn on. If it is running normal, the indicator on the tail cap will flash twice with red followed by green, which indicates that this flashlight is in standby mode and ready to use.
This flashlight also features USB charging. Through USB interface, it can fulfill USB charging directly and conveniently. The intelligent touch switch tail cap has a built-in battery indicator, which can always perform the charging status.
After charged, this flashlight can be applied for self defense, law enforcement, tactical uses and so on. It is really a good lighting tool.
After knowing the above information, you can easily see that this multifunctional tactical IMALENT DM21 CREE XM-L2 LED flashlight is really advanced, outstanding and amazing. If you are searching for high quality LED flashlight, this one is definitely your top choice.
