new build ,,canister style , tripple xhp70
PilleLED
Hello
long time no see.
first i wish all of you a happy new jear , with a lot of light
i am on the way to do a canister torch ,,,my last one with 3600 Lumen is done
the second with 7000 lumen is done ,,,
Now
light head will be a tripple xhp70
canister in delrin , i was thinking about a 5s3p li-ion 18650
switch , hall via reed step 1 , 1 led
step 2 , two leds
step 3 three leds
questions ,,,,,,,how to setup the battery with PCB ,,,,never done it,,,wiring
18650 will be the Lg with 3500MAH
and the driver ;;;;;;;good question
if someone can tell me
how to wire the cells , great
Driver ,,,,no idea yet , i will talk with the feller from PCB components
any help is welcome
PS ; my last canister torch with 7200 Lumen is WWWOOOOOOOOWWWWW
realy cool
many thanks , i with you all the best with a lot of light
and dont look in to...
Stefan
PilleLED
Hello everyone
i need a litle help
to Build a 6s3p
with pcb and ballanced,
for my new build ,
Best Regards
S
H20doctor
seattle
Hi , the cree XHP70 and XHP50 chip are fairly new on the builds ... that means drivers are still being developed to push Or run them at correct voltage ... 4 amps or higher... I would try posting in the LED forum or doing a search on CPF... As for me I just got my XHP70 chip ... and I am also Looking at a good solid high beast of a driver .... the only driver that I have used , and works really well with 100 % reliability is from Taskled .. the H6cc .. its a solid driver and has never let me down...
AS for a Battery pack , I dont build Lithium Ion packs ... I use NiHm ... there less expensive .. and airline friendly when traveling ... I build a 10 cell 1.2 4/3 af cells ...14.2 volts fully charged .... this pack will run just about any chip for 2 hrs ..
So thats my advice for you ... good luck with your build
