I was comparing these 2 knives that I already have. The Spyderco Paramilitary 2 and a 511 Tarani. The back straps are identical. The blades are different for obvious reasons, but when I stack them on top of each other, the lines are identical. The Southern Grind Bad Monkey looks very similar to the 2 here.
The Southern Grind Bad Monkey is the best 'Emerson Wave' equipped knife I've ever used... That's the patented system that allows the knife to be engaged (i.e. opened from it's folded position) in the same motion that you draw it out of your pocket. I'd previously owned an Emerson CQC-6 knife with the wave feature, but the Southern Grind Bad Monkey is exponentially better in that it never fails to deploy (unlike the Emerson), and it's also seriously mean looking! Take a look:
I have a bad monkey and I highly recommend it. Very sharp and great quality. However it is very large so if you don't like large knives you should pass.
