Logan
nmiller
Cleveland, Ohio
Hey all,
Trying to decide which Logan to get. I have an old fixed level 2 Logan and want to upgrade with a 17500 version. Should I special order a fixed level? I'm thinking of going with a level 2 and a level 6. I figure with newer LEDs they both will be brighter than my level 2. I would definitely go with the neutral tint. Other option is get the qtc. What do you think? I like the simplicity of on/off with plus momentary. The qtc kind of scares me......
gunga
Vancouver, BC, Canada
Well. I have a level 6 neutral xpg Logan in stainless head with an 17500 alloy body and stainless momentary switch and extra stainless keychain attachment.
Also have the peak battery kit that allows it to use AA, cr123, AAA, and 17500 in the same light.
Edit : might not have the momentary but will check tonight.
gunga
I just mean that the qtc takes up space in the pill. Once removed you need to fill up that space with metal. Foil is just an easy choice.
