Extreme Micro Questions
KuanR
Macau S.A.R.
I'm looking at the Extreme Micro in titanium and have a few questions.
Does the light have a H-M-L or L-M-H mode sequence?
Does it work with PWM or constant current?
Will it work on a regualr CR2 cell with reduced output?
Hoping someone could help me out before I make up my mind, thank you.
TnC_Products
Arizona
I have used both variations. I believe the last ones were L-M-H.
It is a PWM driver
The light is designed for 3.7v cells. It might light on a CR2 cell but only in the lowest setting and probably not for very long. the CR2 is pretty much at the battery protection cutoff voltage. These were designed to use the IMR 15270 batteries.
Hope this helps.
KuanR
Macau S.A.R.
Hey Chris,
Thanks for answering my questions.I was really hoping to run CR2 cells and have a battery vampire that could drain it to the last bit of usable power.
It is a PWM driver
Hope this helps.
TnC_Products
Arizona
I am not sure one of my 1-watt drivers would fit in this light. If I have a 1-watt driver it would most likely be a single mode. Driving an LED at 350mA.
