archimedes
I have one of the earlier SF E2DL versions (the 200 lumen rated type, IIRC) and just noticed an odd "feature" ....
The UI on these is fairly simple - always starts on High, and cycle briefly for Low.
Recently went to use this for the first time in quite a while and the start mode (High) had been replaced with a fast Strobe.
It would still cycle normally to Low, and then back to Strobe. Regular (non-flashing) High was no longer available.
I switched to a different flashlight until I could investigate further. I then replaced the batteries with fresh and full cells and, not surprisingly, it returned to normal functioning.
When I tested the old cells on a ZTS, both read as below 10% capacity, essentially empty.
Is this strobe a "low battery warning" ... a known feature ?
I don't recall either this having been discussed before, or even ever noticing this happen, although I rarely run multi-primary battery setups all the way empty.
Anyone else notice this, or have related info ?
