Introducing XTAR ROCKET SV2 Battery Charger
XTAR Light
Vendor
China
Video:
For more info please visit:
http://www.xtar.cc/products_detail/&productId=151.html
Thank you!
1c3d0g
This charger is FAST!!! I've topped up my Orbtronic 3500 mAh 18650 battery from 75% to 100% in around 10-15 minutes. Extremely impressive!!! :twothumbs
FlashKat
Anaheim, CA.
I am also impressed with my XTAR Rocket SV2. I charged my 26650 5200 mAh battery in 2 hours from 23% to 100%.
recDNA
Is USA plug standard? It mentions it under optional accessories. What is recommended amps for Eneloop AA NiMH? I will look forward to reviews. This looks like a really nice charger. Wish it showed voltage but I have a multimeter so I guess not a huge issue.
XTAR Light
Vendor
China
We provide different plug for different countries including US and the package includes the wall adapter and car adapter. The recommend charge current for the battery is 0.5C, it depends on the battery capacity.
Thank you for you interesting in XTAR ROCKET SV2 battery charger!
Collins
Does this remember what amp setting you had used last?
Let's say you use 1 Amp charging. Unplug it, then plug it back in. Will it remember your 1 Amp setting used last, or do you have to reset it to 1 Amp every time?
start90a
No, it starts every time from 1 A setting.
You have to switch through 2, 0.5, 1, 2, ... to select your choice.
lonelyboy
Sorry, we are not sure yet. But glad to know that you are interested in! Thank you!
Me too, if XTAR has the 4 bays version with the same max charging current on each bay, I will buy one without hesitation.
Collins
Xtar is coming out with the Dragon that has 4 bay at 1Amp and 2 bay at 2Amp.
I'll be getting that instead of the 2 bay Rocket.
Been waiting for 4 bay 1Amp charger at minimum.
Collins
That would be okay since I'd be just using the 1Amp unless I needed 2Amp charging.
But Xtar will be releasing the Dragon, and so it has 2 Bay 2 Amp charging, and so I'll just go with that.
