Help with my MR11 HID head conversion to LED
mddolson
Belleville, Ont, Canada
This light started lift as a DIY trail tech/WA MR11 10W canister light.
I'm a machinist & don't know much electronics so need some advise.
I can do simple soldering, but have managed to toast my ballast by connecting it in reverse polarity.
This is a dive light so needs are simple, on/off or on/off, hi/lo.
I have attached my lamp head for space limits.
My battery is a lithium Ion : http://www.dx.com/p/9800mah-12-6v-r...-battery-for-cctv-devices-100098#.VxaVvXrprui.
It's actual capacity is 3.3 Ah. (not 9.8)
For led I chose http://www.dx.com/p/20mm-10w-1000lm...dule-for-flashlight-white-235039#.V2ko2qLpqzk
but also found these:
http://www.dx.com/p/20mm-10w-980lm-...uminum-board-silver-white-217421#.V2krDKLpqzk
OR http://www.dx.com/p/20mm-cree-xm-l2...for-flashlight-black-grey-199058#.V2krrqLpqzk
I have no idea why one would be better than another (hens need advise).
For a reflector I chose: http://www.dx.com/p/35mm-35mm-alumi...r-cree-led-emitters-2-pack-14599#.V2kqY6Lpqzk
based on reading in the forum.
Now the driver???? This is where I'm lost.
Reading specs I picked a 3mode http://www.dx.com/p/t6-2500-3000ma-...or-diy-flashlight-4-5-18v-128269#.V2klSqLpqzk
3 modes, I can live with, although the strobe is not required. But I have not idea how to modify it, nor want to risk damaging it.
Question should this be potted/encapsulated? Before installation (concerned about damaging windings?)
Advise & directions are needed & greatly appreciated.
DBwfY8ieRSfYTj4IKeQ0UrTNDwLZHsHvu9jc6UgCMJN4v8DZ64EZyofrSAAAAAASUVORK5CYII=
Mike D
mddolson
mddolson
US
Brand 20mm 10W 1000lm 8300K Cool White Emitter Board Module for Flashlight - White
ColorWhite
Quantity1
MaterialAluminum alloy + LED
Emitter BrandCree
Emitter ModelXM-L2 U2
Output Power10W
Luminous Flux1000lm
Base Size20mm
Driving Current3000mA
Voltage3.0~4.2V
ApplicationFor flashlight
Other FeatureColor temperature: 8000~8300K; Cool white light
Packing List1 x Board
Modelwy6825
ColorBlack + Golden
Quantity1
MaterialBase Plate + Electronic components
Operating Voltage3V~12V / 8.25W
Current2500mA
Mode Arrangement100% light On / 50% On / 10% On / Fast strobe 8Hz / SOS Cycling
Board SizeDiameter: 22mm; Thickness: 10mm
Mode MemoryNo
FunctionsSuitable for driving LED
Other FeatureWith anti- reverse battery protection function
Packing List1 x LED driver board
what not fit together
mddolson
I have ordered another driver, http://www.ebay.ca/itm/191709509869 to replace the one above.
Cree 10W T6 XML XM-L2/U2, component of torch flashlight or 12V Battery Car Light.
Diameter: 20mm
Thickness: 15mm
Iutput Voltage: DC12V
Output Voltage:DC3V
Current: 2.5A
Operating Temperature: -20~80 degree
Storage Temperature: -20~80 degree
Function: Open circuit, Short circuit and Over loading
Mike D
mddolson
Bench model testing is done.
Found single mode 10w driver. Decided on Carclo optic rather than reflector & lens.
I purchased a 6" x 1.5" dia 6061-T6 aluminum rod, hope to start turning the heat sink this weekend.
