Sold/Expired WTS: Surefire Custom E head Triple led
shrike2222
Republic of Korea, US shipping address
1. Surefire E head with Triple luxeon Red Orange led 617nm $150-> $125 -> $115 SOLD
Specs.
Surefire E Head with Triple LED modification
Spec.
1. Surefire E head Hard Anodized
2. Triple Luexon Rebel led, Red Orange 617nm 402lm @ 2100mA
3. Carclo 10507 Clear Narrow Optic Lens
4. Linear driver for 1*li-ion battery (Input voltage 2.8v ~ 4.2v)
(Nanjo-105C 2800mA max output)
5. Tailcap current 141mA(Low)-861mA(Middle)-2763mA(High) by test with Sanyo 16650 2100mAh unprotected cell
6. Custom Copper Heatsink
7. Aluminium mcpcb
8. No waterproof
9. This is not shock proof. I can not guarantee when lens is broken. Because E series head's lens is not found on market or any other OEM manufacturers.
Be careful when you use this. Also do not tight head with too much strength.
Choose driver's mode options. See photo.
If you do not message, driver mode will be set default.
- Current will be varied it's condition. Above output is measured by Sanyo 16650 2100mAh
- This light is for only single li-ion battery, Do not use two CR123 batteries.
- Head is opend. No waterproof. If you want waterproof, use epoxy on head's thread.
- Battery is not included.
- Registered airmail is default option. I need up to 10 business day to ship it.
- No returns or refunds. Only I can accept if light is not turn it on.
- Send message if you have any questions.
2. Surefire E head with Cree XP-G2 WW 90 CRI $150 -> $125 -> $115
Spec.
2. Triple Cree XP-G2 3000K 90 CRI
4. Astrolux S1 A17DD-L FET+1 Flashlight Driver Only for single li-ion battery.
5. Tailcap measured current.
1) 3mA-15mA-136mA-464mA-759mA-1748mA-3526mA with LG HG2 3000mAh unprotected cell
2) 2151mA with Sanyo 16650 2100mAh unprotected cell
6. 0.5㎟ Wire (AWG 20)
7. Custom Copper Heatsink
8. Noctigon DTP Copper mcpcb
9. No waterproof
10. This is not shock proof. I can not guarantee when lens is broken. Because E series head's lens is not found on market or any other OEM manufacturer.
Driver UI (link)
While off:
- Fully click and release to turn the light on. It will go to the
first mode or the last-used mode, depending on whether you enabled
mode memory.
While on:
- Short tap: Do a short (less than 0.5s) half-press to go forward to
the next mode.
- Med tap: Do a medium (0.5s to 1.5s) half-press to go backward to
the previous mode.
- Long tap: Do a long (longer than 1.5s) half-press to reset to the
first mode (if mode memory is turned off).
- Or fully click and release to turn the light off.
Hidden modes:
- Go backward from moon to access the hidden modes. They are, in
order:
- Turbo (just like the regular turbo)
- Tactical strobe (10 Hz)
- Battery check / beacon mode
(each blink represents about 25% of a full charge)
0 blinks: < 1% full (< 3.0V)
1 blink : 1% to 25% full (3.0V to 3.5V)
2 blinks: 25% to 50% full (3.5V to 3.8V)
3 blinks: 50% to 75% full (3.8V to 4.0V)
4 blinks: 75% to 100% full (4.0V to 4.2V)
5 blinks: > 100% full (> 4.2V)
- Biking flasher (2-level stutter beacon, 1 Hz)
Configuration options:
- Short tap rapidly a bunch of times (15+ taps, or until the light
stops turning on) to enter soft config mode.
The way it works is the light will blink twice for each option,
then pause for a bit before moving to the next option. Turn the
light off between the two blinks to toggle that option.
The available options are:
- Mode group: 7 modes or 4 modes:
Group 1: moon, low, med1, med2, high1, high2, turbo
Group 2: low, med, high, turbo
- Mode memory toggle
- If CONFIG_STARS is defined, you can ground pin 3 of the MCU to
enable mode memory instead of using config mode. This can often
be done by soldering a star on the spring side of the driver, if
your driver supports that. Otherwise, it's pretty easy to make a
solder bridge from pin 3 (mode mem toggle) to pin 4 (ground). Or
even just wedge a piece of metal between the two pins.
Other details to note:
- Low-voltage protection will progressively step down the output at
about 2.8V, and the light will shut itself off when even the
lowest level gets below 2.8V.
- The default turbo step-down is 45 seconds.
- When turbo steps down to high, a short tap will push it back up to
turbo or a medium tap will step down further, even if you got to
turbo by going backward from moon. The step-down effectively
moves it from the "hidden" turbo back to the non-hidden turbo.
- A short tap from any hidden mode will return to the lowest mode.- Current will be varied it's condition. Above output is measured by LG HG2 18650 battery and Sanyo 16650 2100mAh battery
- This head is for only single li-ion battery with unprotected cell.
- This head produces much more heat. Do not leave it with turned on!
- Head is opened. No waterproof. If you want waterproof, use epoxy on head's thread.
- Battery and E2e body are not included.
E2e body is not included.
Below current is tested by LG HG2 3000mAh
Below beam shot is tested by LG HG2 3000mAh
Below current is tested by Sanyo 16650 2100mAh
Below beam shot is tested by Sanyo 16650 2100mAh
Send PM first.
Thank you for looking.
Kim.
