NEXTORCH light
There is always a time where a quick shift of focus is needed. Search operations and exploration require a focused light beam in order to get the greatest distance from the light, whereas trekking, camping and mountain climbing need a broader light beam, to brighten up a wider part of the terrain. For this, Nextorch came out the Fresnel lens technology and worked it out to the PA5 flashlight.
Rotate Focus
To adjust the flashlight to the right focus, NEXTORCH designers devoted themselves to research and development of lighting effects, got a brighter beam using Fresnel lens reflecting optics optical focus technology, and applied their creativity to design a flashlight that sets the PA5 apart from the other focus flashlights on the market, with a beam that's fuller and rounder, with a smoother transition as the light beam is adjusted.
Good color rendering and strong light penetration
The PA5 uses a CREE XP-L medium white light LED. Compared with cold white light, the LED has a better color rendering, letting you better distinguish objects in detail and evaluate their distance. Also, the PA5 functions well in rainy and foggy environments. Its stronger penetration pierces the mist, giving added protection to make excursions safer.
USB Rechargeable
The PA5 works with CR123A lithium battery which functions at low temperature (non-rechargeable) and also works with the large capacity 18650 lithium-ion battery (included). The flashlight comes with a patented Pull-up charge cap structure. Pull out the card ring to charge, and also to support the flashlight standing on end, convenient and practical.
Stable and Reliable
The PA5 flashlight body uses aerospace grade aluminum alloy 6061-T6 made with CNC precision machining casting and made more durable with mil spec III type hard anodic oxidation surface treatment. It's solid work you can feel the moment you pick up the flashlight.
The flashlight body is easy to hold single handed, crafted with a square knurling texture, which is not only more comfortable in the hand, but also prevents slippage to ensure a good grip control at all times. The powerful cylinder body is part of the PA5's excellent performance. It features IPX-4 waterproof grade, shock resistance tested to 1 meter drop, so it functions in a variety of adverse environments, delivering unbeatable stability.
The PA5 360° rotating focus USB rechargeable flashlight, with floodlight and narrow beam focus full functionality, whether it is for outdoor excursions, law enforcement expeditions, regular patrols or maintenance inspections, can help you cool deal with a multitude of surprises.
