SUNWAYMAN C13R- 380 Lumens Multi-functional Intelligent USB Charging Flashlight
sunwayman
--Soft-contact side switch--
Features
● CREE XM-L2 U3 LED, with a lifetime of up to 50,000 hours;
● Slightly depress the side switch to turn on/off the flashlight as well as selecting desired output mode:
Turbo (380 lumens, automatically lowers to High after 3 mins continuous use); High (180 lumens, 2 hrs ); Mid (50 lumens, 10 hrs ); Low (10 lumens, 60hrs );
Strobe; SOS; Aviation Signal
● USB charging interface, can be charged by laptop, charger baby or direct power supply
● Constant current circuit, constant output
● Uses one single CR123A(16340、18350)battery
● Working voltage: 2.8~4.2V
● High quality metal smooth reflector maintains great throw distance and spread with an ideal beam pattern;
● Dimensions: 78mm (length) x 32mm (head diameter) x 25mm (tail diameter)
● Weight: 72.8g(battery excluded)
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-6 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Accessories: Lanyard, O-rings, Battery holder
