jumpstat
Hi all,
It has been 9 years since I received this light and recently are having some contact problems. I have issues getting proper contact with certain batteries and after careful investigation found that the +ve contact on the board have worn out and is now lower than the original due to wear from rubbing.
What would be the best way to rectify this issue? I am assuming that a new blob of solder is needed. What would be the best way to do it?
As I am based in Malaysia, sending it over to Hawaii is a concern for me, so would like to do it myself. Do i need to remove the board or just leave it in the head for the soldering works? Or sending it back to McGizmo would be the sensible option?
Thanks in advance.
Thanks in advance.
