Manker MK34(12*Cree XP-g3/ 12*Nichia 219B) is releasing
Manker
UPDATE: Manker MK34(12*Cree XP-g3/ 12*Nichia 219B/ 12*Nichia 219C) is releasing
Update: MK34 Nichia 219C version is available.(4000k, CRI 90+)
Manker MK34 Flood Flashlight 12 Emitters 8000 Lumens Runs of 3 18650 Batteries
Key Features:
1. 12 Emitters (3 quad MCPCBs)
2. Max output 8000lumens with Cree XP-G3 emitter,6500 luemns with Nichia 219B emitter
3. Working voltage: 2.8V-4.35V (Over discharge protection)
4. Reverse polarity protection and battery indicator
5. Most efficiency constant current circuit driver
Specifications:
1.Emitter: 12 Cree XP-G3 / 12 Nichia 219B (two version for your choice)
2.Maximum output: Cree XP-G3 8000 lumensNichia 219B 6500 Lumens
3.Maximum beam intensity:
Cree XP-G3 20000CD, maximum beam distance 280 meters.
4.Working voltage: 2.8V-4.35V (Over discharge protection)
5.Driver: Most efficiency constant current circuit
6. Material: Aircraft-grade aluminum body
7. Surface treatment: Premium Type III hard-anodized anti-abrasive finish
8. Lens: Toughened ultra-clear glass lens with anti-reflective coating and TIR
9. Water proof: IPX-8 (2 meter under water)
10. Impact resistance: 1.5 meters
11. Tail stand
Dimensions:
Length 98mm, Diameter 55mm
Weight 278g (Without battery)
Accessories: O-ring *1, Lanyard*1, User manual*1
Output and runtime:
Moonlight: 0.1-30lumens /2months-5days, Low: 120lumes 30hours
Medium 1: 500lumens 7.5hours , Medium 2: 1000lumens 3.5hours
High: 2500lumens 2hours , Turbo: 8000lumens, Strobe: 8000lumens
Batteries:
MK34 runs of 3 18650 batteries.
MK34 must use high drain unprotected 18650 batteries.
(Recommend: NCR18650GA )
(The package does not include any battery)
Side switch battery indicator:
1. Blue: More than 75% 2. Purple: 50% 3. Red: Less than 20%
Lock out:
One click-Double-Triple from any mode to lock out the flashlight.
(Only the battery indicator works when lock out)
Engineering Mode(Choose output level for Moonlight mode): Long press for off and still hold on, the side button battery indicator will turn on and then quick click for 4 times to get access to engineering mode. One click to check different level and long press to make your final choice.
For more information please visit Manker website: http://www.mankerlight.com/manker-mk34-flashlight-12x-led-3x-18650/
Lex Icon
200000 CD ???Maybe you meant 20000 CD !!!
***apparently they saw my post and corrected their error��
Zak
What sort of driver does this thing have? The obvious competition, the Noctigon Meteor uses a boost driver that seems to keep output reasonably consistent outside of thermal and low-voltage protection.
What tint will the XP-G3 version be? How about making a version with the Nichia 219C?
And the most important bit: what's the planned price point? This light looks nice, but not necessarily better than the Meteor. If it cost less, that would raise its appeal considerably.
twistedraven
I'm assuming the XP-G3 will be one of the highest flux bins, so probably around 6500k. The 219B will probably be similar to what was in the E14, so 5000k.
Vinh will most likely get a hold of this light and mod it and offer his own LEDs, one of which being the 219C.
It's listed at 130usd on Manker's website; available now.
I like the form factor of this light much better than the meteor, which is a little too wide in the grip to be comfortable. I always thought a 3x 1860 meteor would be nice, and Manker's done it.
Naturally, runtimes won't be as long, and the optics are more floody compared to the M43, so there are tradeoffs.
Skeeterg
Very cool,and a nice price to. WTG Manker.
I love your guy's pen light to.
SG Hall
Sampson Flat, Sth. Aust.
Regarding modding this one, I'll suggest that a power boost is possibly all that is easily done ( driver maybe). The stock light offers a choice of emitters, but to swap out a dozen will be very expensive for a modder.
This looks like a great stock light to me rather than a modders dream. :)
nfetterly
Cincinnati area, but lots of travel
I have the Manker E14 (quad) in 219B, love it, ordered the XP-G2 version - knowing I don't particularly like cool LEDs. Ordered one from Vinh with XP-L HI and his driver. Really like the E14 form factor so I wanted two of them.
If I got this I'd settle for 6500 lumens.
Glenn7
Tasmania, Australia (the butt end of oz)
yes got one coming should be here by monday - other than the fact it's smaller than the M43 I like that the optics are protected much better with the body than the M43 with a thin bezel ring and a big glass lens which is always in the back of your head if you were to drop it.
Blue Steel
Looking forward to seeing your impression and results of this light, Budda.
Boots45acp
Arizona
My tracking info shows mine will be delivered tomorrow.
10 days from China to So. Calf. 3 days of this was being held in customs.
Couldn't resist ordering one - just on looks alone.
Very interested to see how this compares to my Noctigon M43vn (Goldilocks Mod)
Boots45acp
Arizona
No comparison to your goldilocks (maybe in tint if you got the Nichia) but your Goldie will have 5x the throw and 3000 lumens more, but the spill is brilliant on my nichica m34 and size is good too
My MK34 arrived today.
First impressions are very positive.
I have only played with for about 10 mins.
Excellent build quality.
Great size and comfortable in your hand.
I don't think I will be selling my Goldilocks anytime soon, based in large part to the differences that you accurately pointed.
Can't wait for the sun to go down and check this little bad boy out....
