18GT-36, KLARUS FIRST WITH IMR 18650 FUNCTION
klight
Dear Klarus Fans,
Since the XT11GT available, we supply great battery 18GT-36 for XT11GT to support it works as great as ppssiable.
This battery aslo could use for other normal flashlight which use 18650.
Let's see details!
Have a nice weekend!
Klight!
Mrty
I just purchased a XT11GT from Amazon and with it received a 18650 3100 mah battery rather than 3600 mah. I inquired to Klarus and received this response from Sarah. "Regarding battery, the battery we provided for upgraded XT11GT which is 18650-3100.
3100 IMR battery is better than 3600.
Which could drive flashlight to high quicker and stable, bring less heats"
Is this true ?
LeafSamurai
Christchurch, NZ
Is this true ?
I think she meant the LED for the first version of the Klarus XT11GT, the XHP35 HI, was driving the flashlight too much, thus making it too hot, and not the battery itself, that was causing the problem.
However, they substitute the 3600mah battery for the 3100mah either as a cost-saving alternative, or they are indeed worried that the 3600mah batteries could drive the second version of the light harder similar to the first version, which is highly unlikely in my opinion.
The LED of the second version of the Klarus XT11GT, the XHP35 HD, is much better, in my opinion, as although it does not have the long throw of the first version, it have a larger spill which suits my purpose. Hope that helps.
Mrty
LeafSamurai thanks for your response I totally agree that 3600 is better. The light they sent was the new XHP 35D. I believe I will return paid to much anyway
Mr Baz
The 3100 cell is an IMR and not protected thus able to drive the turbo mode it drops to 1300 lumens with protected cells. IMR ones tend to have slightly lower capacity but can handle the higher power drain better. I got a later production XT11GT it has the 3100 IMR included.
fluke
London UK
If anyone is interested I just took one of the 3600 cells apart.
LGEBMJ118650.
3.7V 3500mAh 10A LG 18650MJ1 Li-ion battery
Specifications
Voltage: 3.7V
Capacity: 3.5Ah / 3500mAh
Size: Dia. 18mm x Height 65mm
Cut off Voltage: 2.75V
Full charge Voltage: 4.2V
Max. Discharge Current: 10A / 10000mA
