SUNWAYMAN T20CC- 1000 Lumens Tactical Flashlight with Excellent Design Details
sunwayman
Rugged Crenulated Bezel, Magnetic Control Slider Switch
Tri-color Light Sources, Intelligent USB Charging System
Features:
● CREE XM-L2 U3 LED, with a lifetime of up to 50,000 hours;
● Tail switch to turn on/off; Magnetic control slider switch for different mode switching; Head switch to select desired output mode.
Turbo: 1000 Lumens (Automatically lowers to High Mode after 3 mins continuous use)
High: 600 Lumens (2 hours)
Mid: 300 Lumens (7 hours)
Low: 40 Lumens (42 hours)
Moon Mode: 1 Lumens (300 hours)
Red Light; Green Light; UV-light.
The T20CC is equipped with 365nm UV-light LED, which is invisible by human eyes, but this light can be used to check whether there is fluorescer in diapers, clothes, toys or cosmetics etc. daily supplies. Also, it's used to check jewelries such as amber, wax jade and so on.
● Constant current circuit, constant output
● Uses one single 18650 or two CR123A(16340) batteries
● Working voltage: 2.8~4.2V
● Rugged Crenulated Bezel under Emergencies
● Low-voltage Protection
● Dimensions: 141mm (length) x 32mm (head diameter) x25.4mm (tail diameter)
● Weight: 116.6g(battery excluded)
● Aerospace-grade aluminum alloy material
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Accessories: Lanyard ,O-ring
Operation:
1. There are 4 constant output modes, 3 hidden modes, one moon mode as well as 3 color outputs.
2. Depressing the tail switch to turn on the light, with the slider switch at the lower end, the light is under color output mode, the upper end the Turbo constant output mode.
a. When under constant mode, click the head switch button once for one mode, which cycles through Low-Mid-High-Turbo. The light goes to High automatically after 3 mins at Turbo.
Double-click the head switch button to enter hidden modes and it comes at Strobe, hold the switch to cycle through Strobe-SOS-Aviation Signal. A single or double-click will enter constant output modes.
When under constant output mode, hold the switch to enter moon mode, and another depress and hold will enter Low mode.
b. Moving the slider switch to the lower end, it enters color mode, click the head button to cycle through green-UV light-red and moving the slider back upwards, it resumes constant output mode.
3. Charging: Depress the tail switch and plug in the USB cable to charge the light, the red light will be on and the main white light does not work; when it's fully charged, the indicator lamp will be green, and the light can be turned on only when the USB cable is cut-out.
4. Low-voltage Protection
When inserting battery, the indicator lamp will flash to indicate the voltage tested, when it's between 3-4V, it flashes 3 times.
When the voltage lowers to 3V, the indicator lamp will be turned on constantly to indicate it's low voltage.
When uses 4.2V battery and the voltage lowers to 2.8V, the indicator lamp flickers and the white light flashes 5 times and then turn off.
Chicken Drumstick
UK
Looks good, just some observations.
-There seems to be no pocket clip?
-Nice that it has a moonlight mode, although at 1 lumen it's still a little on the highside.
-An XP-L HI would be a nice addition/option and I'd have thought more suited to a 'tactical' light?
-NEEDS a neutral white LED tint option. Preferably an XP-L HI.
LAMPARITA
USA
How to carry a tactical light without pocket clip and holster? Maybe in the black case shown in photo?
naked2
Upland, CA
I miss the V series, my favorite Sunwayman lights; will you ever add new models to the V series with new LEDs, or at least re-introduce existing models with new LEDs?
