VP2 XStar Help, set up but no charge indicator on screen?
gingagooner
Hi,
Thanks for adding me, i am new to this forum.
i bought a VP2 Xstar charger for my anti smoking Vapour batterries.
I set up as per instructions and off of tables on line
i have 2 x ICR 18650 3.7v 40A rechargable batteries
the online info said to set at 3.7 v and 1 amp charge,i have done this and no battery charge status light comes on the screen, despite clearly showing some form of status should show on how much charge there is and the progress?
I am now unsure if its faulty or i am being a numpty and setting wrong, lost the plot with it now though, so could do with some advice if any body has any expertise on this please??
many thanks,
James - Essex - England!!
cyclesport
You should have a status display even with no batteries if the unit is getting power. Sounds like your settings are correct (for the fastest 18650 charge)...are you sure you inserted the batteries in the correct polarity? I have a couple of VP2's and and my charging choices are 3.2, 3.6 and 3.8v...no 3.7v?
