I do not know what is the best driver for two types of LEDs
cpassuel
Hello,
With your 11,1v battery, you need a linear driver for the first led (eg. battery voltage is more or less led voltage) and for the second led, you need a buck driver (led voltage is smaller than battery voltage).
There are good led drivers at taskled. There are several drivers available, maybe someone can help you to choose the best for your case.
DIWdiver
Connecticut, USA
...you need a linear driver for the first led...
Uh, no. That would be a buck-boost, or sepic driver. Linear drivers require the battery voltage be higher than the LED voltage, just like buck drivers.
Taskled's b3flex would work well on the XML2, but he does not make buck-boost drivers.
