Olightworld
- Joined
- Dec 11, 2014
- Messages
- 579
The brand new S30R Baton III is the third iteration of our flagship S30R flashlight series. We have refined and perfected the magnetic charging system including fast charging so you have light when you need it the most. The smaller body while maintaining the performance of the larger S30R style head and lens gives the light great distance while also having a balanced flood as well. We are proud of our design and technology evolution and we really got it right on this one guys.
Available for pre-order now at http://www.olightstore.com/led-flashlights/tactical/olight-s30r-baton-iii
FEATURES:
INCLUDED ACCESSORIES:
FEATURES:
- One customized 3500mAh 18650 battery included providing a maximum output up to 1050 lumens
- Utilizes a smooth aluminum reflector which provides an improved beam focus for medium and close-range illumination paired with a hardened glass lens that is coated allowing for a 99% light transmission rate
- The S30R III is shorter by 3mm in length, reaching 114mm than the previous S30RII
- Magnetic tail cap that allows it to be secured to ferrous metal surfaces for hands free work
- New USB desktop charging dock provided. This flashlight also has a charging port that is compatible with Olight magnetic charging cables which can be used for charging on the go
- Low power and Lockout indicator under the side switch. When the battery voltage is running low (below 3.1V) or when the flashlight is locked out and being clicked, it will glow red
- Thermal management program to protect the users' hand and flashlight from heat. The 1050 lumen turbo mode will stay on for two minutes before stepping down to the 500 lumen high mode within one minute.
- Direct access to turbo mode: when the flashlight is off and not under lockout mode, double click to activate the turbo mode
- Timer function: long timer (9 minutes) and short timer (3 minutes)
- Flashlight (with stainless steel clip)
- Customized 3500mAh 3.6V 18650 battery (included in the flashlight)
- Lanyard with Perforating Tool
- 4.2V 1000mAh Desktop Charging Dock
- 50cm Micro-USB Cable
- Instruction Manual
