Manker E12 2AA 650 lumens Flashlight is releasing
Manker
Features:
Emitter: Cree XP-L V5 CW & NW for your choices
Battery: 2 AA batteries
Working Voltage: 0.9Volt-4.2Volt
Maximum Output: 650Lumens
Maximum Beam Intensity: 2300cd
Maximum Beam Distance: 96 Meters
Most efficiency constant current driver, Maximum run time 100 hours
Clip: Stainless steel clip
Lens: Toughened ultra-clear glass lens with anti-reflective coating
Waterproof: IPX-8(2 meters under water)
Impact resistance: 2 meters
Size&Weight:
Length: 145mm
Diameter: 20mm
Weight: 51g (without battery)
Accessories:
Stainless steel bezel*1
O-ring *1
Lanyard*1
User manual*1
Output & Runtime:
Moonlight 2lumens(300 hours)
Low 56lumens(16.5 hours)
Medium 260lumens(4.5 hours)
High 650lumens(2 hours)
Strobe 650lumens
Operation:
Tactical switch on the tailcap is the on/off button.
Half press from off to momentary on(memory your last used output) and release for off.
Single click to turn on the light(memory your last used output) and single click for off.
Side switch(modes selection switch)
When the light is on, single click to cycle through the modes as in the figure.
Long press for strobe and single press to your last used mode.
Note: strobe is not included in memory function.
More details please visit:
http://www.mankerlight.com/manker-e12-650-lumens-cree-xp-l-v5-led-flashlight/
scs
Could better tailstand if it had 2 holes for the lanyard attachment.
proceed5
Hi Manker,
Noticed the operating voltage of the E12 is up to 4.2 volts.
Therefore, can I remove the battery-body extension tube and use One (1) 14500 Li-Ion to power the light with full functionality ?
(just like the E21 ?)
Your reply is much appreciate, thank you.
