TR18 in my eyes, smaller and lighter than TR20
rofisbenny
TR18 is all back, aero grade aluminum alloy material.
TR18 is shorter than TR20. The measurement shows that the length is 124.3 mm(it shortens the length to 14.7mm than TR20), diameter is 24.5mm, weightis 131 g (include the magnets tail and clip).
TR18 using CREE XP-L V3 LED and bead in center, micro orange light cup has good floodlight effect, more convenient and practical to meet illumination needs for home, travel, and the great outdoors. coupled with the lens using double-sided coated glass, maximize light efficiency and scratch protection against internal LED.
The side buttons are compacted around the stainless steel pressure ring to ensure adequate dustproof and waterproof performance.
Aluminum Alloy side switch has two halves transparent arc power indicator lights, power indicator light will display remaining battery power(only available when 18650 lithium battery is use ).
After the light turned on or switched the mode(the special modes are excluding) 3 seconds, the power indicator built into the switch will illuminate 3 seconds to indicate remaining battery power. The green power indicator will illuminates when power level is above 50%,and the red power indicator will illuminate when the power level is below 50%.When battery power is close to depletion, the red power indicator will blink quickly.
The side switch simultaneously has the positioning function. With the light switched on, keep pressing the switch until the power indicator be activated, the green power indicator to blink twice every three seconds, thus helping users locate the TR18 in dark conditions.
The side has four symmetrical shallow trough, both reduce their own weight and played a decorative role, and take into account the function of the cooling slot.
The adjustable head incision is located the middle position of four slot, the head and the body of the torch can be rotated 0-150 degrees, compared with the TR20 (90 degrees), the rotate angle has been upgraded. Specific operation as follows: hold the body of the torch by your right hand and put your right thumb on the switch.
Then secure the body by left thumb and index finger, use your right hand to turn the body towards yourself and your left hand to turn the head outwards until the head and the body of the torch become the angle you need.
---From Aguai's experience report for ROFIS TR18
