The comparison between TR20 and TR18
rofisbenny
Comparison between TR20 and TR18
TR18: CREE XP-L HI V3 LED, a micro-textured reflector, moonlight 2 lumens, low light 16 lumens, medium light 65 lumens, high light 230 lumens, turbo 1100 lumens, length 124.3mm, can be rotated 150 degrees, can not direct charge.
TR20: CREE XP-L HI V3 LED, the lens using double-sided coated glass, moonlight 5 lumens, ultra low 10 lumens, low light 80 lumens, medium light 280 lumens, high light 500 lumens, turbo 1100 lumens, length 139.0mm, can be rotated 90 degrees, can direct charge.
Under the comparison in the same lumens, there is some differences in color temperature between the TR18 and TR20 , TR18's light more yellow and high light areas were bigger.
The comparison of spot diagram in 2 meters between TR18 and TR20 (Turbo):
Night shot comparison:
10 Meters Distance
50 Meters Distance
10 Meters Distance
20 Meters Distance
30 Meters Distance
100 Meters Distance
---From Aguai's experience report for ROFIS TR18
