Imalent DN35---a powerful led flashlight up to 2200 lumrns
imalent
Shenzhen
Product Details
The IMALENT DN35 is a versatile USB rechargeable LED tactical flashlight with multi-level outputs and an OLED display. The OLED display shows the battery voltage, output, charging status, and has a flashing overheat warning, which makes it easier to know the status of the flashlight. Utilizing the latest four-level output CREE XHP35 HI LED, the tactical-switch button makes it easy to operate. With a maximum output of up to 2200 lumens, the IMALENT DN35 can produce a strong beam of light up to 596meters away. Supported by a single cell of IMALENT 26650 4500mAh Li-ion rechargeable battery, its advanced temperature control module, low-voltage warning, and low-power protection make for a satisfying experience no matter the occasion.
Product Features
·Utilizes the latest CREE XHP35 HI LED. The lifespan up to 50000 hours with ·maximum output of 2200 lumens. Includes a built-in USB charging interface
·The OLED display can show various parameters.With high drain 4500mAh 26650 Li-
·ion rechargeable battery
·Product size: 113(length)*38 (head diameter) *32 (diameter) mm
·Net weight:115g
·High efficiency constant power circuit will maintain constant brightness
·Anti-reverse battery protection
·Built-in thermal control module will automatically adjust the brightness output
·according to the working state and outer temperature
·Combination of toughened ultra-clear mineral and anti-reflective coating glass
·Optimized deep metal reflector maintains great throw distance and spread with an ·ideal beam pattern
·Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface
·treatment
·IPX-8 standard waterproof (2 meters submersible)
·1.5m impact resistant
·Tail stand function
We are looking for dealers and distributors worldwide. Please send us email at [email protected] if any interest.
Best regards,
Shellen
IMALENT marketing team
Skype: imalent_shellen
LumenTodd
Scottsdale, AZ
Here is the DT70 they sent me. They won't respond to my emails in regards to this. Straight out of the box.
LT :fail:
nibrud
Thanks for the info. I'll avoid until customer service improves.
gamez
and they dont answer my question either...
they sell a product and announce false values to trap people -.-
(see my post above)
that's not correct
jedi_master
hi,
you say:
but in the specs page of this LED, i can see a maximum output of 1483 lumens.
link here: http://www.cree.com/LED-Components-and-Modules/Products/XLamp/Discrete-Directional/XLamp-XHP35-HI
so what's the deal? why the "commercial" value is so different from the technical value?
thanks
Italian guy tested the light and the results are:
Low: 25
Med: 506
High: 1280
Turbo: 1836
Lux: 74K (542M)
http://www.cpfitaliaforum.it/phpbb/viewtopic.php?f=22&t=13739#p218309
Not too shabby for a small light. I suspect the result could be better with a high drain unprotected cell like iJoy.
With discount, I am getting both DN35 and DN70!
brightnorm
Excellent Light with serious design flaw:
Performance-wise the DN35 is an excellent light. Unfortunately, the ergonomic functionality is among the worst of the many lights I have used. Aside from the unnecessary second button, made superfluous by superior single button designs such as the Nitecore MH series, the inaccessibility of the buttons makes the light virtually non-functional in the field, in darkness, or whenever quick reaction is desired.
In an apparent attempt to make the light unique (OLED display, blue end cap, etc) the designers have, IMO, almost defeated the usefulness of an otherwise very fine light. I devised a crude mod that gets around the problem, but I hope that Imalent will resolve this unnecessary design flaw in the next iteration of the DN35.
Brightnorm
imalent
Shenzhen
sorry for missing the message, could you pls contact us with the mail [email protected], because the picture you posted had been missed, we will respond once we receive your mail, thanks
imalent
Shenzhen
Dear gamez, sorry for that, we handed over the job and missed the message, your advice is appreciated. we will respond the message in 24hrs, and try our best to solve any problems you have, pls contact us with the email:[email protected]
Alan From New York
I like the DN35 except that in the dark, the switches take forever to find, blending too well with the body. Beautiful beam, though.
