rofisbenny
- Joined
- Sep 19, 2016
- Messages
- 93
Model: ROFIS TR10
TR18 is all black, aero grade aluminum alloy material. Oxide layer is very thick. Ultra compact and lightweight. The length after the head rotated only 72 mm, so cute!
The side has four symmetrical shallow trough, both reduce their own weight and played a decorative role, and take into account the function of the cooling slot.
The adjustable head incision is located the middle position of four slot, the head and the body of the torch can be rotated 0-90 degrees,hold the body of the torch by your right hand and put your right thumb on the switch.
Then secure the body by left thumb and index finger, use your right hand to turn the body towards yourself and your left hand to turn the head outwards until the head and the body of the torch become the angle you need.
After TR10 straightened, the length is 82mm (3.22''), diameter is 22mm (0.86'').
Utilizes a CREE XP-L HI V3 LED, a micro-textured reflector offers wide angle lighting, more convenient and practical to meet illumination needs for home, travel, and the great outdoors. coupled with the lens using double-sided coated glass, maximize light efficiency and scratch protection against internal LED.
---From Aguai's experience report for ROFIS TR10
