rofisbenny
- Joined
- Sep 19, 2016
- Messages
- 93
:thumbsup:Side button are pressed tight by stainless steel pressure ring, the side button more higher than the pressure ring, so it is easy to operate, and you can quickly find the side button in the dark environment. Internal battery indicator light, when the voltage is less than 2.6V, the red power indicator will blink twice every seconds. At the same time,the side switch with lock function to prevent accidental illumination, namely press and hold the switch for 3 seconds to enter lockout mode when in the shutdown state. (However this way is not very convenience, if set to press the side switch four times to locking or other means, so even if the light in your backpack, it will never mistakenly touch unlock.)
TR10 comes with stainless steel titanium-plated clip, detachable.
Cylinder body is full of square knurling, can play the role of anti-skid. Tail cover a week is also full of square knurling, convenient to operate the tail cover.
The hole in the side, thread the lanyard also has tail stand capability.
Tail built-in magnet.
TR10 support 1×16340 or 1×CR123 battery.
---From Aguai's experience report for ROFIS TR10:twothumbs:thumbsup:
