SubLGT
The test was published online Nov. 2016
http://www.autoexpress.co.uk/accessories-tyres/76760/best-car-headlight-bulbs-group-test
The Philips X-treme Vision +130 had unimpressive performance.
The continuous improvements to bulb tech have seen top performers claiming at least twice the light of standard bulbs at some point in the beam. But are the claims justified? We tested nine in Philips' light tunnel in Aachen, Germany, to find out…
Topping this test is the new RacingVision from Philips, with a clear margin over Ring's plus 130 per cent bulb. Close behind is the GE Megalight Ultra from Halfords...
Philips has developed LED versions of the popular H7 and dip and beam H4 lamps...These produce a beam that meets current rules for filament bulbs. In our test, the rating was on par with the winning RacingVision, but the light was whiter and much broader. It wasn't as smooth, though; you could see the LED chips in one section...Philips would do well to pursue these and get the law changed to allow their use in Europe...
