Acebeam X65 5* CREE XHP35 HI LED 12000lm 1301m Throw Flashlight Global Testing
acebeam
Acebeam recently release new generation of Tactical flashlight with rechargeable function of X65, In order to make the flashaholics to experience Acebeam new model, we are now collecting Acebeam X65 Global Testing Campaign. Look forward to your participation and support!
Acebeam X65 Description:
The X65 builds on the success of recent Acebeam models such as the K60, K70 and X60M which have achieved critical acclaim as some of the brightest and best-made LED flashlights on the global market.
The X65 is fitted with five CREE XHP35 HI emitters, Powered by a custom-made 6,800mAh 14.8V lithium-ion battery pack, the X65 delivers a digitally regulated beam of up to 12,000 out-the-front lumens with an intensity of 423,000 candela, equivalent to a throw of 1,301 meters using the ANSI formula.
The X65 is controlled from a single switch which is easy to find in the dark and to operate with either hand. A single click of this switch accesses a previously memorized mode (Low, Mid or High) while a double click accesses Turbo (6,000lm) and another double click, Turbo-Max (12,000lm).
The X65 is supplied with a universal power pack to charge the battery from any AC supply.
X65 Operation:
1. To charge the battery, connect the supplied universal power pack to a mains supply (110/220v AC). Unscrew the DC Lock cap on the tail-cap and connect the lead from the power pack. A red light on the tail-cap indicates charging in progress, while a green light indicates charging is complete. A full charge will take three hours. Disconnect the power pack when the green light appears and re-attach the DC Lock cap. Note that the battery pack can be charged independently of the head.
2. Turn the flashlight ON and OFF by clicking the switch.
3. Press-and-hold the switch to cycle through Low, Mid and High modes. Release the switch to memorize your preferred mode – the light will return to this mode next time the flashlight is turned ON.
4. To access the Turbo mode, double-click the switch while the flashlight is ON. To access Turbo-Max, double-click from Turbo. Additional double-clicks will cycle between Turbo and Turbo-Max, while a single click will turn the flashlight OFF.
5. To access the Ultra-Low mode, press-and-hold the switch from OFF for one second. From Ultra-Low a single click will return the flashlight to the mode memorized in step 3 above.
6. To access the Strobe, triple-click the switch from the ON or OFF position. A single click will return the flashlight to the mode memorized in step 3 above. Note that Turbo, Ultra-Low and Strobe settings are not memorized.
7. To Lock Out the X65 (to prevent accidental activation and depletion of the battery while the flashlight is not in use), press-and-hold the switch from the OFF position for two seconds. The beam will flash twice to indicate successful Lock Out. To Unlock, press and hold the switch for two seconds, until Ultra-Low mode is activated.
Declaration of the campaign
Time of application: 21 February 2017~ 7 March 2017
Form of application: send email to [email protected], introduce yourself including experience on reviews, which flashlight modes you reviewed before.
Requirements for the applicant: Individuals who can post their testing reports on more than one internet media or other relevant, such as website, blog, forums of flashlight, outdoor, photography, magazines and newspaper etc.;
The contents much include: Description and your personal feeling of the product; Images and video of the products, including appearance.
Report publicize effective time: Participants should publicize the report within 25days after receiving the X65, and send the related link to [email protected] .
Notice: 1. Acebeam will contact and select participants by sending emails within 24hrs, if no replies received without 48hrs means we are still in considering your status.
2. Acebeam have the ownership to use/forward the report including works, images, videos,etc.
3. Acebeam reserves the right of interpretation of this testing campaign.
Umbrosoccer
Sent you guys an email. I'd like to do a video review on this light.
-Jon
