sonnyangell
- Joined
- Feb 23, 2017
- Messages
- 2
Hello!
I am looking for a solution to my issue with a blue laser diode, I had purchased one on amazon that is 405nm 3V/5V 20mW. I need to have a constant beam to be emitted from this diode for an ON-stage lighting effect, as a test..originally I had this working with 2 simple AAA batteries, and it worked perfectly.
https://www.amazon.com/dp/B014WZV9DA/?tag=cpf0b6-20
However after trying again with a new laser diode of the same output, the beam dims after a second or two.. I will shut off the laser and try again with the same outcome. I need a constant beam that can be seen without smoke. Could you offer some advice on this?
Thank you!
-Sonny
Thank you!
-Sonny
