Hi there
here we are so glad to introduce you our newly developed some types of the products
1. for C2-3000, each slot we can get 1.5A output, and also for C2 series our engineers have developed the full-automatic function, that means, you no need select the charging current from 150ma 250ma 350ma to even 2000ma and our charger can test the inner resistance of the battery and the charger will select the charging current automatically from 100ma 150ma 200ma for 50ma one step till 1500 ma
2. for the large charging current, our future defelped products for C2-6000, C4-10 , will have more than 2A charging current, for C2-6000 each channel can have 3A charging current and for C4-10 each slot can have maxium 3A output current
also for the large battery 26650, our C4-10, will load all four battery in the charger.
3. for the heat radiation, from C2-4000 we will fix a little fan in the body of the charger
here would you please send us your email address and your mail address or give us your contact method
here we already have C2-3000in hand ,for the other types just on developing.
we would like to give you the introduction for C2-3000 and sample for free, and you can review and evaluate it.
welcome reviewer contact with [email protected]
Thanks and have a good day.
Miboxer | C2 | C4 |
Size | 158mm*103mm*38mm | 144mm*80mm*46.5mm |
Weight | 285g(N.W) 445g (G.W) | 285g |
Material | Fire Proof PC+ABS | Fire Proof PC+ABS |
Color | Black | Black |
Input Voltage /Current | AC86-265V 50-60Hz 0.4A (MAX) 18W DC12V 2A | DC 5V-12V 2A |
Output Voltage | DC 4.35V±0.1%/4.2V±0.1%/3.6V±0.1%/1.48V±0.1% | DC 4.20V±1% / 1.48V±1% |
Output Current | Li-ion: 800mA*4(High) / 350mA*4(Low) Ni-MH / Ni-Cd: 300mA*4(High) / 150mA*4(Low) | Li-ion (MAX) 2*1.5A Ni-MH/NiCd (MAX) 2*1A |
Compatible with | Li-ion / IMR / INR / ICR / LiFePO4 10340, 10350, 10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14350, 14430, 14500, 14650, 16500,16340(RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490, 18500,18650, 18700, 20700, 21700, 22500, 22650,25500, 26500, 26650 Ni-MH / Ni-Cd: AA, AAA, AAAA, C | 4.20V(Li-ion / IMR / INR / ICR)10340 / 10350 / 10440 / 10500 / 12340 / 12500 / 12650 13450 / 13500 / 13650 / 14350 / 14430 / 14500 / 14650 16500 / 16340(RCR123) / 16650 / 17350 / 17500 / 17650 17670 / 18350 / 18490 / 18500 / 18650 / 18700 / 20700 21700 / 22500 / 22650 / 25500 / 26500 / 26650Ni-MH / Ni-Cd(1.48V) AAAA / AAA / AA / A / SC / C / D NO LiFeP04 |
