Manker MK41 2000 Lumen Cree XHP35 HI/HD Led 4 AA/14500 Popcan Flashlight is Releasing
Manker
Manker MK41 2000 Lumen Cree XHP35 HI/HD Led 4 AA/14500 Popcan Compact Thrower Flashlight is Releasing
Specifications:
1.Emitter: Cree XHP35 HI / HD (CW and NW for your choices)
2.Maximum output: 2000lumens for HD CW version (NW version output is about 20% less than CW)
3.Maximum beam intensity: 67500 CD (520 meters)
4.Working voltage: 2.5V-7.2V 10V-16.8V (Over discharge protection)
5.Driver: Most efficiency constant current circuit driver
6. Material: Aircraft-grade aluminum body
7. Surface treatment: Premium Type III hard-anodized anti-abrasive finish
8. Lens: Toughened ultra-clear glass lens with anti-reflective coating
9. Water proof: IPX8 (2 meters under water)
10. Impact resistance: 1.5 meters
11. Tail stand
Dimensions:
Length 105mm, Head Diameter 44mm
Weight 191g (Without battery)
Accessories: O-ring *1, Lanyard*1, User manual*1 Holster*1
Operation:
1.When the flashlight is off , one click ,access to moonlight mode (left part of the figure),
one click to circle: moonlight-Low-Medium-High. Long press for off.
2.When the flashlight is off, long press to access to the mode your last use as in left part of the figure (Memory function), one click for circle. Long press for off.
3.When the flashlight is off, double click access to Turbo, one click for circle. Long press for off.
4.When the flashlight is on, double click to switch between the two groups(left and right part of the figure)
5.Long press for off and still keep on pressing will get into dragon breath mode directly.
Side switch battery indicator:
1. Blue: More than 75% 2. Purple: 50% 3. Red: Less than 20%
Lock out:
One click-Double-Triple from any mode to lock out the flashlight.(Only the battery indicator works when lock out)
Engineering Mode(Choose output level for Moonlight mode): Quick click for 4 times from any mode to get access to engineering mode. One click to check different levels and long press to make your final choice.
Please visit http://www.mankerlight.com/manker-mk41-compact-thrower-4x-aa-14500-flashlight/ for more details.
turboBB
NJ, USA
Here's an in-depth vid review of both the HI & HD; features both indoors & outdoors beamshot comparo's vs. other 4 x AA (albeit older gen) lights (Sunwayman D40A, ThruNite TN4A XP-L V6, Jetbeam SRA40) as well as Runtime on Turbo with various batteries:
EDIT: Apologies for the horrendous audio for majority of review, had incorrect setting on the camera... :(
EDIT 2: Written review now posted: http://www.candlepowerforums.com/vb/showthread.php?432278
turboBB
NJ, USA
Here's a demonstration (and measurements) of the different output levels one can program for the Moonlight and Turbo modes of the MK41 HD & HI:
ericwp
Dear Manker, I received the MK41 yesterday and I'm very impressed with this little AA light. Bright, nice beam, easy interface, hate to say it, my wife thinks its a cute flashlight..but I have one issue with my model. While not a deal breaker when the light is tail standing the symbol on the power button is angled to the right about 30 degrees and not perpendicular. Is there a way I can straighten it? Most likely I'll get used to it but for now its a little annoying..lol I would attach a picture but it seems you can only attach one from a url and not upload one..should be able to do both.
Thank You
EricWP
Manker
Thank You
EricWP
Hello Ericwp,
Thanks for your interest in our products.
The metal part on the side switch is rotatable so you can rotate it to any direction you need.
ericwp
Hi Manker, How do I get warranty service?
One of the brass pins on the tail cap fell out; the ones that fit in the holes and line up the tail cap before you screw it in. I went to change the batteries and the pin was in the flashlight body and not on the tail cap.
Is there a way to fix it or do I need a new tail cap?
Thanks
EricWP
Manker
Thanks
EricWP
Hello EricWP,
Sorry for the inconvenience that may caused.
Please contact [email protected] for after sale service.
KuffJaR
Banned
Wow, 1300 lumens for 10 is worth looking into as well What kind of batteries do those use?
