Help with LEDs Powered from Small Format Battery
daijizai
As far as most maker stuff goes, I am a total n00b. I have a hobby project at hand to design a glowing playing card to emulate Gambit from X-Men helping someone pull together a cosplay getup. I know how to make it work at 12v, but I would love to get it to 3.7v for a small LiPo.
I guess my question is: With the LEDs wired in parallel, I don't have sufficient current; in series, I don't have sufficient voltage. I have neopixel rings that can power a dozen leds off the same 3.7v battery. What can I look in on and read up on to figure this circuit out?
Image is the series circuit.
tm77T
http://imgur.com/a/tm77T
Thanks in advance!
ssanasisredna
Are those white or Red LEDs?
If red you should be able to adjust the resistors to get enough current .
daijizai
Red, but the resistors are already fairly minimal. I forget what I put on there at the moment, but I know they were the lowest values that I have. I am thinking that maybe I have them wired up completely wrong? I've seen dozens of LEDs powered on the same voltage. There has to be a smarter way?
I have been jammed at work and some long hours, but I should have some time to tinker in the evenings starting next week. I hope to find the solution soon.
Thanks for the thought though. I'll look into it, but I am thinking there must be more to it.
