2017 Acebeam X45 16500lm 4*XHP70 LED flashlight is releasing
acebeam
Arm yourself with the ultimate weapon against the forces of darkness!
Acebeam's new X45 delivers up to 16,500 lumens and 85,200 candela - enough to light a huge area for first-responders, farmers, sailors and other outdoor activities which don't stop when the sun sets.
Four Cree XHP 70 P2 emitters powered by four special high-drain 18650 protected batteries deliver a digitally regulated broad beam for long periods - for example 4,000 lumens for well over an hour and 1,500 lumens for 3.5 hours. Surprisingly light and compact, the X45 is designed for single-handed operation and built to take years of hard use.
Here comes the sun!
Pick up the new 16,500 lumen Acebeam X45 and you're holding the sun!
The X45 is equipped with four top-of-the-range Cree XHP 70 P2 LEDs, powered by four special high-drain protected 18650 lithium ion batteries. It offers a choice of six brightness levels from a 3-lumen Firefly mode to the 16,500-lumen Turbo Max, as well as a "hidden" strobe.
Fitted with Acebeam's 3,100mAh ultra high-drain protected batteries and a thermo-sensitive resistor to avoid overheating, the X45 will deliver 16,500 lumens for approximately three minutes or 9,000 lumens for ten minutes before stepping down to a digitally-regulated 4,000 lumens for over an hour. On the Mid setting it will run for 3.5 hours at 1,500 lumens, while Firefly mode will operate for more than 12 days.
The orange-peel reflector delivers a broad beam with a peak intensity of 85,200 candela, equivalent to a throw of 583 metres by ANSI FL1 standards, making the X45 indispensable for any application that requires wide-field illumination such as lighting up a construction site or accident scene, docking a boat or navigating tricky terrain off-road.
The X45 is built to take years of hard use, being waterproof to 2m (IPX 8) and impact resistant to 1.2m. The aircraft-grade aluminium housing is hard-anodized with a premium Type III anti-abrasive finish and the tempered and coated glass lens is protected by a stainless steel crenelated bezel. A clever "concealed hanging ring" provides a secure anchor point for a lanyard. It is supplied with a holster, lanyard, spare o-rings and Acebeam's 5-year limited warranty.
Contact your Acebeam dealer to put the sun in your hand and a smile on your face, all right?
