acebeam
- Joined
- Apr 1, 2015
- Messages
- 279
The first fitted with four CREE XHP70 LED emitters now present by Acebeam Flashlight, In order to make the flashaholics to experience Acebeam new model, we are now collecting Acebeam X45 Global Testing Campaign. Look forward to your participation and support!
Acebeam X45 Description:
* Four CREE XHP70 LED, Max output 16500lm
* Max beam throw 538m
* Peak beam intensity 85200cd
* Power by 4pcs high drain cell(including)
* Voltage indicator light beside the switch
Output modes:
Firefly: 3lm(310hrs)
Low: 500lm(10hrs)
Mid: 1500lm(3.5hrs)
High: 4000lm(1.4hrs)
Turbo: 9000lm(10mins)~ 4000lm(1.2hrs)
Turbo Max: 16500lm(3mins)~4000lm(1.1hrs)
X45 Operation:
1. Turn the flashlight ON and OFF by clicking the switch.
2. Press-and-hold the switch to cycle through Low, Mid and High modes. Release the switch to memorize your preferred mode – the light will return to this mode next time the flashlight is turned ON.
3. To access the Turbo mode, double-click the switch while the flashlight is ON. To access Turbo-Max, double-click from Turbo. Additional double-clicks will cycle between Turbo and Turbo-Max, while a single click will turn the flashlight OFF.
4. To access the Ultra-Low mode, press-and-hold the switch from OFF for one second. From Ultra-Low a single click will return the flashlight to the mode memorized in step 3 above.
5. To access the Strobe, triple-click the switch from the ON or OFF position. A single click will return the flashlight to the mode memorized in step 3 above. Note that Turbo, Ultra-Low and Strobe settings are not memorized.
6. To Lock Out the X45 (to prevent accidental activation and depletion of the battery while the flashlight is not in use), press-and-hold the switch from the OFF position for two seconds. The beam will flash twice to indicate successful Lock Out. To Unlock, press and hold the switch for two seconds, until Ultra-Low mode is activated.
Declaration of the campaign
Time of application: 6 April 2017~ 15 April 2017
Form of application: send email to [email protected], introduce yourself including experience on reviews, which flashlight modes you reviewed before.
Requirements for the applicant: Individuals who can post their testing reports on more than one internet media or other relevant, such as website, blog, forums of flashlight, outdoor, photography, magazines and newspaper etc.;
The contents much include: Description and your personal feeling of the product; Images and video of the products, including appearance.
Report publicize effective time: Participants should publicize the report within 25days after receiving the X45, and send the related link to [email protected] .
Notice: 1. Acebeam will contact and select participants by sending emails within 24hrs, if no replies received without 48hrs means we are still in considering your status.
2. Acebeam have the ownership to use/forward the report including works, images, videos,etc.
3. Acebeam reserves the right of interpretation of this testing campaign.
Output modes:
Low: 500lm(10hrs)
Mid: 1500lm(3.5hrs)
X45 Operation:
